rage加密工具
消耗积分:0 | 格式:zip | 大小:0.21 MB | 2022-05-20
刘桂英
分享资料个
授权协议 Apache
开发语言 Rust
操作系统 跨平台
软件类型 开源软件
软件简介
rage 是一个简单、现代、安全的文件加密工具,使用 age 格式。它的特点是小的显式密钥,没有配置选项,以及UNIX风格的可组合性。
Usage:
  rage [--encrypt] -r RECIPIENT [-i IDENTITY] [-a] [-o OUTPUT] [INPUT]
  rage --decrypt [-i IDENTITY] [-o OUTPUT] [INPUT]
Positional arguments:
  INPUT                       Path to a file to read from.
Optional arguments:
  -h, --help                  Print this help message and exit.
  -V, --version               Print version info and exit.
  -e, --encrypt               Encrypt the input (the default).
  -d, --decrypt               Decrypt the input.
  -p, --passphrase            Encrypt with a passphrase instead of recipients.
  --max-work-factor WF        Maximum work factor to allow for passphrase decryption.
  -a, --armor                 Encrypt to a PEM encoded format.
  -r, --recipient RECIPIENT   Encrypt to the specified RECIPIENT. May be repeated.
  -R, --recipients-file PATH  Encrypt to the recipients listed at PATH. May be repeated.
  -i, --identity IDENTITY     Use the identity file at IDENTITY. May be repeated.
  -o, --output OUTPUT         Write the result to the file at path OUTPUT.
INPUT defaults to standard input, and OUTPUT defaults to standard output.
RECIPIENT can be:
- An age public key, as generated by rage-keygen ("age1...").
- An SSH public key ("ssh-ed25519 AAAA...", "ssh-rsa AAAA...").
PATH is a path to a file containing age recipients, one per line
(ignoring "#" prefixed comments and empty lines).
IDENTITY is a path to a file with age identities, one per line
(ignoring "#" prefixed comments and empty lines), or to an SSH key file.
Multiple identities may be provided, and any unused ones will be ignored.
评论(0)
发评论
下载排行榜
