Hyduino Speeduino H2 Gms气体管理系统
消耗积分:0 | 格式:zip | 大小:0.05 MB | 2022-08-09
手托初梦
分享资料个
电路板图如下:
Hyduino (Speeduino+ H2 Gms (气体管理系统)
包含的类型信息 组装所需的制造商 型号# Digikey P/N CAP TANT 10UF 35V 10% RADIAL Tantalum Kemet Y T356G106K035AT 399-3654-NDCAP CER 0.22UF 50V 10% RADIAL X7R Kemet Y K224K20X7RF5UH5 BC2678CT-ND CAP CER 0.1UF 50 % RADIAL X7R Kemet Y C322C104K5R5TA 399-4329-ND CAP TANT 47UF 6.3V 10% RADIAL Tantalum AVX Corporation Y TAP476K006CCS 478-4180 - NDCAP CER 0.33UF 50V 10% RADIAL X7R AVX Corporation Y AR215F3334K4R CER 50V 10% 径向 X7R Kemet Y C317C103K5R5TA 399-4206-ND CAP CER 1UF 50V 20% RADIAL X7RKemet Y C330C105M5U5TA 399-4390-ND CAP CER 4700PF 100V 10% RADIAL X7RKemet Y C317C472K1R5TA 399-4243-NDDIODE ZENER 5.6V 3W AXIAL DO-41ON Semiconductor Y 1N5919BG 1N5919BGOS-ND DIODE SCHOTTKY 50V 1A AXIAL 轴向 ON Semiconductor Y MBR150G MBR150GOS-NDLED SS 3MM 625NM RED DIFF 5mm-LED N LTL-4221N 160-1139-ND DIODE GEN PURPOSE 400V 1A DO41 DO-41 Micro Commercial Co Y 1N4004-TP 1N4004-TPMSCT-ND浪涌吸收器 14MM 22V 1000A ZNR Disc 14mm Panasonic - ECG Y ERZ-V14D220 P7307-ND接线端子               PCB 2POS 5.0MM 绿色
Phoenix Contact N 1935161 277-1667-ND SHUNT JUMPER .1" BLACK GOLD N 969102-0000-DA 3M9580-ND CONN HEADER .100" SNGL STR 40POS Sullins Connector Solutions N PREC040SAAN-RC.. S1012EC-40-ND MOSFET N- CH 33V 62A TO-220 TO-220 STMicroelectronics Y STP75NS04Z 497-5981-5-ND RES 10K OHM 1/4W 5% 轴向 Yageo Y MFR-25FBF52-10K 10KQBK-NDRES 1.00K OHM 1/4W 1% METAL FILM Yageo Y MFR-25FBF52-1K 1.00KXBK-ND RES 680 OHM 0.6W 1% AXIAL TE Con​​nectivity Y 1622545-1 A105963CT-ND RES METAL FILM 1/4W 470 OHM 1% AXIAL Stackpole Electronics Inc Y RNF14FTD470R RNF14FTD470RCT-ND 2.49k Ohm 1% 0.25W, 1/4W 通孔电阻轴向金属膜 Yageo Y MFR-25FBF52-2K49 2.49KXBK-ND RES 3.9K OHM 1/4W 0.1% 金属膜 AXL Yageo Y MFP-25BRD52-3K9 3.9KADCT-NDRES 100K OHM 1/4W 1% 金属膜 Yageo Y MFR-25FBF52-100K 100KXBK-NDRES 160 OHM 2W 1% 轴向国巨 Y FMP200FRF52-160R 160YCT-ND IC 稳压器 LDO LM2940-5.0 1A TO220 TO-220 Texas Instruments Y LM2940T-5.0/NOPB LM2940T-5.0/NOPB SENSOR ABS PRESS 36.3 PSI MAX 6-SIP Freescale Semiconductor Y MPX4250AP.. MPX4250APIC MOSFET DVR 3A DUAL HS 8-DIP 8-DIP Microchip Technology Y TC4424EPA TC4424EPA-ND TVS ARRAY ESD 6 INPUT 30V 8-DIP 8-DIP Littelfuse Inc. Y SP721APP F2720-ND Y AR08-HZL-TT-R AE10011-ND                                                         不适用 不适用 1050-1018-ND 材料总数:制造成本
1
Arduino 超级 2560
1
Speeduino 屏蔽板
评论(0)
发评论
下载排行榜
