CC2567,pdf datasheet(带集成天线的ANT和蓝牙双模单芯片模块)
消耗积分:0 | 格式:exe | 大小:322 KB | 2011-02-27
分享资料个
The CC2567-PAN1327/17 is the first dual-mode, ANT and Bluetooth solution in the market. This solution is a highly-integrated class 2 HCI module with increased output power capabilities offered by Panasonic using TI’s CC2567 ANT+ and Bluetooth 2.1 + Enhanced Data Rate (EDR) dual-mode transceiver. Based on TI’s 7th generation Bluetooth technology, the solution provides best-in-class Bluetooth RF performance of +10 dBm typical Tx power and -93 dBm typical receiver sensitivity. The CC2567-PAN1327/17 module allows customers to connect to mobile phones and computers over Bluetooth from ANT+ enabled devices, and allows customers with Bluetooth solutions to add ultra low-power ANT+ connectivity. This solution is provided as a module to help customers reduce development time, lower manufacturing costs, save board space, ease certification, and minimize RF expertise required.
评论(1)
发评论
xuliya 2013-08-21
0 回复 举报
谢谢楼主 收起回复
下载排行榜
全部1条评论
