AB PANELVIEW人机界面使用说明
消耗积分:0 | 格式:pdf | 大小:6.91 MB | 2011-04-19
liuxin
分享资料个
  Solid state equipment has operational characteristics differing from those of electromechanical equipment. Safety Guidelines
  for the Application, Installation and Maintenance of Solid State Controls describes some important differences
  between solid state equipment and hard-wired electromechanical devices. Because of this difference, and also because of the
  wide variety of uses for solid state equipment, all persons responsible for applying this equipment must satisfy themselves
  that each intended application of this equipment is acceptable.
  In no event will Rockwell Automation, Inc. be responsible or liable for indirect or consequential damages resulting from the use or
  application of this equipment.
  The examples and diagrams in this manual are included solely for illustrative purposes. Because of the many variables and
  requirements associated with any particular installation, Rockwell Automation, Inc. cannot assume responsibility or liability
  for actual use based on the examples and diagrams.
  No patent liability is assumed by Rockwell Automation, Inc. with respect to use of information, circuits, equipment, or
  software described in this manual.
评论(2)
发评论
bhsxwp 2012-09-25
0 回复 举报
感谢 收起回复
游客 2011-07-18
0 回复 举报
谢谢! 收起回复
下载排行榜
全部2条评论
