Arduino LED 8位数字显示
消耗积分:0 | 格式:zip | 大小:0.03 MB | 2023-01-04
王利祥
分享资料个
这是一个非常简单的项目。您只需将 8 个 LED 连接到 Arduino,然后输入一个数字,LED 就会显示该数字。
private void Send_Click(object sender, EventArgs e)
           try
               int IntValue = Convert.ToInt32(Value.Text);
               if (IntValue >= 0 && IntValue <=255)
                   string ToSend =Value.Text +";"+ ToBinary(Value.Text);
                   Console.WriteLine(ToSend);
                   port.WriteLine(ToSend);
               else
                   MessageBox.Show("Invalid Input", "Error");
           catch (Exception ex)
               MessageBox.Show(ex.Message, "Error");
       private string ToBinary(string data)
           string result = string.Empty;
           int rem = 0;
           try
               int num = int.Parse(data);
               for (int i = 0; i < 8; i++)
                   rem = num % 2;
                   num = num / 2;
                   result = rem.ToString() + ";" + result;
           Seprate(result);
           return result;
       private void Seprate(string result)
           String[] bits = result.Split(';');
           if (bits[7] == "0") { p0.Checked = false; } else if (bits[7] == "1") p0.Checked = true;
           if (bits[6] == "0") { p1.Checked = false; } else if (bits[6] == "1") p1.Checked = true;
           if (bits[5] == "0") { p2.Checked = false; } else if (bits[5] == "1") p2.Checked = true;
           if (bits[4] == "0") { p3.Checked = false; } else if (bits[4] == "1") p3.Checked = true;
           if (bits[3] == "0") { p4.Checked = false; } else if (bits[3] == "1") p4.Checked = true;
           if (bits[2] == "0") { p5.Checked = false; } else if (bits[2] == "1") p5.Checked = true;
           if (bits[1] == "0") { p6.Checked = false; } else if (bits[1] == "1") p6.Checked = true;
           if (bits[0] == "0") { p7.Checked = false; } else if (bits[0] == "1") p7.Checked = true;
评论(0)
发评论
下载排行榜
