RTL8367RB/RTL8367MB寄存器表
消耗积分:2 | 格式:pdf | 大小:0.63 MB | 2023-01-05
PCB92178558
分享资料个
RTL8367RB/RTL8367MB寄存器表免费下载。
1.VLAN...................................................................................................................................................................................5
1.1.ENABLE VLAN TABLE CONTROL REGISTER..........................................................................................................5
1.2.VLAN CONFIGURATION REGISTER..............................................................................................................................5
1.3.PORT-BASED VLAN CONTROL REGISTER.........................…........................................................7
1.4.PORT-BASED VLAN FID CONTROL REGISTER ....................................…..........................................................8
1.5.PER-PORT VLAN INGRESS CONTROL REGISTER.............................................…..........................................8
1.6.PER-PORT VLAN EGRESS CONTROL REGISTER .................................................................…..........................9
1.7.PROTOCOL AND PORT VLAN CONTROL REGISTER.....................................................................….....................9
2.RMA...................................................................................................................................................................................14
2.1.RESERVED MULTICAST ADDRESS CONTROL REGISTER ...................................................................................14
3.IGMP .................................................................................................................................................................................16
3.1.IGMP CONTROL REGISTER........................................................................................................................................16
4.ETHERNET AV ...............................................................................................................................................................19
4.1.ETHERNET AV CONTROL REGISTER ........................................................................................................................19
5.LED....................................................................................................................................................................................20
5.1.LED CONTROL REGISTER..........................................................................................................................................20
5.2.LEDX_CFG DEFINITION............................................................................................................................................23
6.CPU PORT........................................................................................................................................................................24
6.1.CPU PORT CONTROL REGISTER.................................................................................................................................24
7.MIRROR ...........................................................................................................................................................................25
7.1.PORT MIRROR CONTROL REGISTER ...….................................................................................................................25
8.STORM FILTERING ......................................................................................................................................................26
8.1.STORM FILTERING CONTROL REGISTER.................................................................................................................26
9.INTERRUPT.....................................................................................................................................................................28
9.1.INTERRUPT CONTROL REGISTER.............…..............................................................................................................28
10.QOS...............................................................................................................................................................................30
10.1.PER-PORT INPUT BANDWIDTH CONTROL REGISTER.....................................................................................30
10.2.PER-PORT OUTPUT BANDWIDTH CONTROL REGISTER…..........................................…................................31
10.3.REMARKING REGISTER ..............................................................................................................................................32
10.3.1.Remarking Control Register............................................................................................................................32
10.3.2.802.1p Remarking Control Register ................................................................................................................32
10.3.3.DSCP Remarking Control Register .................................................................................................................32
10.4.PORT-BASED PRIORITY CONTROL REGISTER...................................….....................................................33
10.5.DSCP-BASED PRIORITY CONTROL REGISTER ..................................................…............................................33
10.6.802.1Q-BASED MAPPING CONTROL REGISTER .......................….....................................................................36
10.7.PRIORITY DECISION CONTROL REGISTER...................….............................................................................37
10.8.OUTPUT QUEUE NUMBER CONTROL REGISTER.............................….........................................................37
10.9.QNUM AND PRIORITY TO QID MAPPING REGISTER.......................….........................................................37
10.10.SCHEDULER CONTROL REGISTER.................…..........................................................................................40
10.11.WEIGHT FAIR QUEUE PARAMETER REGISTER........…...........................................................................42
10.12.APR CONTROL REGISTER .....................................................................................................................................44
11.PHY...............................................................................................................................................................................47
11.1.PHY ACCESS CONTROL REGISTERS............................…................................................................................47
11.2.PHY REGISTERS ........................................................................................................................................................47
12.MIB ...............................................................................................................................................................................49
12.1.MIB CONTROL REGISTER ..........................................................................................................................................49
12.2.MIB DATA REGISTER ................................................................................................................................................49
13.LUT ...............................................................................................................................................................................52
13.1.LUT CONTROL REGISTER..........................................................................................................................................52
13.2.LUT LEARN LIMIT CONTROL REGISTER ...................................................................................................52
14.PORT ISOLATION.....................................................................................................................................................55
14.1.PORT ISOLATION CONTROL REGISTER …...........................................................................................................55
14.2.ENHANCE FID CONTROL REGISTER.....…....................................................................................................55
15.SVLAN..........................................................................................................................................................................56
15.1.SVLAN CONTROL REGISTER.....................................................................................................................................56
15.2.SVLAN MEMBER CONFIGURATION REGISTER ..…........................................................................................57
15.3.SVLAN C2S CONFIGURATION REGISTER.....…............................................................................................60
15.4.SVLAN MC2S CONFIGURATION REGISTER ..…..........................................................................................65
15.5.SVLAN SP2C CONFIGURATION REGISTER...............…............................................................................67
16.PORT ............................................................................................................................................................................74
16.1.PORT ABILITY CONTROL REGISTER .................................................................................................................74
16.2.PORT STATUS REGISTER ............................................................................................................................................74
16.3.EXTERNAL INTERFACE MODE CONTROL REGISTER ....…..............................................................................75
16.4.PORT SECURITY CONTROL REGISTER ...............................................................................................................76
16.5.EEE CONTROL REGISTER ..........................................................................................................................................78
16.6.MISC ..........................................................................................................................................................................78
17.SPANNING TREE.......................................................................................................................................................79
17.1.MSPT CONTROL REGISTER .....................................................................................................................79
18.SHARE METER ..........................................................................................................................................................80
18.1.SHARE METER CONTROL REGISTER..…........................................................................................................80
19.TRUNK.........................................................................................................................................................................84
19.1.TRUNK CONTROL REGISTER ........................................................................................................................84
20.802.1X............................................................................................................................................................................86
20.1.802.1X CONTROL REGISTER..….....................................................................................................................86
21.ACL...............................................................................................................................................................................88
21.1.ACL CONTROL REGISTER..........................................................................................................................................88
22.8051 AND NIC CONTROL ........................................................................................................................................92
22.1.8051 AND NIC FUNCTION CONTROL REGISTER.....….....................................................................92
22.2.NIC POINTER AND STATUS REGISTER.................................................................................................93
22.3.NIC CONFIGURATION REGISTER................
评论(0)
发评论
下载排行榜
