HSW-TMI3342
消耗积分:0 | 格式:pdf | 大小:921.13 KB | 2024-04-09
深圳市华升微电子有限公司
  • 32内容
  • 2.3k阅读
  • 2粉丝
30V, 370kHz, Peak 2A Synchronous Step-Down Converter
Features
⚫ Wide Input Range: 4.5V to 30V
⚫ Output Voltage from 0.8V
⚫ 370kHz Switch Frequency
⚫ Peak 2A Output Current
⚫ Power Save Mode at Light Load
⚫ COT control to achieve fast transient
responses
⚫ Integrated internal compensation
⚫ Stable with Low ESR Ceramic Output
Capacitors
⚫ 250mΩ/120mΩ Low RDS(ON) internal FETs
⚫ Over Current Protection with Hiccup Mode
⚫ Thermal Shutdown
⚫ Inrush Current Limit and Soft Start
⚫ Build in Input Over Voltage Protection
⚫ Available in SOT23-6 Package
Description
The TMI3342 is a high efficiency 370kHz switching
frequency synchronous Buck DC-DC converter
with capability of delivering up to peak 2A current.
TMI3342 integrates both high and low side switch
with low RDS(ON) to minimize the conduction loss.
Low output voltage ripple and small external
inductor and capacitor size are achieved with
370kHz switching frequency.
The TMI3342 requires a minimum number of
external components and
it is available in a 6-pin
SOT23-6 RoHS compliant package.
Application
⚫ Distributed Power Systems
⚫ Security Equipment
⚫ Flat Panel Television and Monitors
⚫ Smart Home
⚫ Industrial Power Systems
评论(0)
发评论
下载排行榜
