MAX4638,MAX4639数据资料
消耗积分:0 | 格式:pdf | 大小:475 KB | 2012-11-15
分享资料个
The MAX4638/MAX4639 are single 8:1 and dual 4:1CMOS analog multiplexers/demultiplexers (muxes/demuxes). Each mux operates from a single +1.8V to+5V supply or dual ±2.5V supplies. These devices feature3.5Ω on-resistance (RON) when powered with asingle +5V supply and have -75dB off-isolation and-85dB crosstalk from the output to each off channel.The switching times are 18ns tON and 7ns tOFF. Theyfeature a -3dB 85MHz bandwidth and a guaranteed0.25nA leakage current at +25°C.
评论(1)
发评论
hunxiyi2009 2014-09-01
0 回复 举报
下载下来看看瞧! 收起回复
下载排行榜
全部1条评论
