模数转换器设计指南 高性能、独立的模数转换器应用于多种嵌入式
消耗积分:0 | 格式:rar | 大小:3482 | 2009-06-12
分享资料个
Selecting the most suitable A/D converter (ADC) for your application is based on more than just the precision or bits. Different architectures are available, each exhibiting advantages and disadvantages in various data-acquisition systems. The required accuracy or precision of the system puts you in a category based on the number of bits required. It is important to always design your system to allow for more bits than initially required: if an application calls for 10 bits of accuracy, choose a 12-bit converter. The achievable accuracy of a converter will always be less than the total number of bits available.
评论(0)
发评论
下载排行榜
