安森美贴片二极管 MBR20H100CT-D
消耗积分:1 | 格式:pdf | 大小:127KB | 2014-08-17
h1654155860.0298
分享资料个
  SWITCHMODE Power Rectifier 100 V, 20 A
  Features and Benefits
  • Low Forward Voltage: 0.64 V @ 125°C • Low Power Loss/High Efficiency • High Surge Capacity • 175°C Operating Junction Temperature • 20 A Total (10 A Per Diode Leg) • Guard−Ring for Stress Protection • NRVBB Prefix for Automotive and Other Applications Requiring Unique Site and Control Change Requirements; AEC−Q101 Qualified and PPAP Capable • These are Pb−Free Devices*
  Applications
  • Power Supply − Output Rectification • Power Management • Instrumentation Mechanical Characteristics: • Case: Epoxy, Molded • Epoxy Meets UL 94 V−0 @ 0.125 in • Weight (Approximately): 1.9 Grams (TO−220) 1.7 Grams (D2PAK) • Finish: All External Surfaces Corrosion Resistant and Terminal Leads are Readily Solderable • Lead Temperature for Soldering Purposes: 260°C Max. for 10 Seconds *For additional information on our Pb−Free strategy and sold
评论(0)
发评论
下载排行榜
