AD8015,pdf datasheet (Transimp
消耗积分:0 | 格式:rar | 大小:517 | 2009-09-23
479461
分享资料个
The AD8015 is a wide bandwidth, single supply transimpedance
amplifier optimized for use in a fiber optic receiver circuit. It is a
complete, single chip solution for converting photodiode current
into a differential voltage output. The 240 MHz bandwidth enables
AD8015 application in FDDI receivers and SONET/SDH
receivers with data rates up to 155 Mbps. This high bandwidth
supports data rates beyond 300 Mbps. The differential outputs
drive ECL directly, or can drive a comparator/ fiber optic post
amplifier.
评论(0)
发评论
下载排行榜
