PCB过孔电流计算器
消耗积分:0 | 格式:xls | 大小:416KB | 2017-04-20
zhongguoyzp
分享资料个
PCB过孔电流计算器
Please Note
I have created the Via Calculator on information I found from various sources.
The via calculator simply converts the drill size into its Circumference And assumes this behaves the same as a trace
Due to a lack of Data I cannot confirm the accuracy of this calculator (use as rough guide only)。
This means it is down to the User to determine its accuracy.Designed
This Program was designed by Phillip Restall and is in no way connected with Aculab plc. By
PCB过孔电流计算器
评论(0)
发评论
下载排行榜
