stm8s003F3P6英文资料
消耗积分:1 | 格式:pdf | 大小:952KB | 2017-04-29
深澜
分享资料个
  Features Core • 16 MHz advanced STM8 core with Harvard architecture and 3-stage pipeline • Extended instruction set Memories • Program memory:8 Kbytes Flash;dataretention 20 years at 55 °C after 100 cycles • RAM: 1 Kbytes • Data memory: 128 bytes of true data EEPROM; endurance up to 100 000 write/erase cycles Clock, reset and supply management • 2.95 to 5.5 V operating voltage • Flexible clock control, 4 master clock sources: - Low power crystal resonator oscillator - External clock input - Internal, user-trimmable 16 MHz RC - Internal low power 128 kHz RC • Clock security system with clock monitor • Power management: - Low power modes (wait, active-halt, halt) - Switch-off peripheral clocks individually • Permanentlyactive, low consumptionpower-on and power-down reset
  2 Description The STM8S003x value line 8-bit microcontrollers feature 8 Kbytes Flash program memory, plus integrated true data EEPROM. The STM8S microcontroller family reference manual (RM0016) refers to devices in this family as low-density. They provide the following benefits: performance, robustness, and reduced system cost. Deviceperformanceandrobustnessareensuredby integratedtruedata EEPROM supporting up to 100000 write/erase cycles, advanced core and peripherals made in a state-of-the art technology, a 16 MHz clock frequency, robust I/Os, independent watchdogs with separate clock source, and a clock security system. The system cost is reduced thanks to high system integration level with internal clock oscillators, watchdog and brown-out reset. Full documentation is offered as well as a wide choice of development tools.
stm8s003F3P6英文资料
评论(2)
发评论
小凡小公举 2020-09-16
0 回复 举报
求资料 收起回复
古小林 2019-07-10
0 回复 举报
求资料 收起回复
下载排行榜
全部2条评论
