如何使BEAGLEBONE基础电器通知消息
消耗积分:0 | 格式:rar | 大小:1.55 MB | 2017-05-08
分享资料个
  一旦洗衣机或干衣机循环开始,用户必须等待一个小时,让他们完成他们的周期。通常,他们忘了检查在家电等湿衣服坐几个小时而成,干燥的衣服坐皱,导致用户的挫折感。而这个项目将向你展示如何设置BEAGLEBONE绿色或BeagleBone Black发送报警文本的任何手机当洗涤或干燥周期完成消除这种挫折感,你所学到的东西可以应用到任何运动项目。
  这是一个现实世界的问题/解决方案的情况下,采用物联网(IOT),解决了一个加速度计,BeagleBone,一些额外的硬件和一些轻规划。通过跟随的过程中,你会熟悉BeagleBone的工作(绿色或黑色),这样做可能会解雇你的想象力的其他应用。同时,你可能想为自己,你的另一半,或朋友
  Let your appliance do the texting
  Given how much time is spent on cellphones, what better way to solve the problem of distraction than to have the washer and dryer send a text when the laundry is done? Without tampering with the machine or the AC power lines, this project shows how to use an accelerometer to detect machine operation. The concept is that the machine vibrates when in operation and the accelerometer is used to detect the presence and absence of that vibration to indicate cycle status.
  For this project, we used both the new Wi-Fi-enabled BeagleBone Green as well as the BeagleBone Black. BeagleBone is a great, stable platform for IoT-targeted applications, with more than enough general-purpose I/O to connect to sensors and expansion boards. Except for the BeagleBone Green’s built-in wireless capability, the setup is identical so they can be used interchangeably.
评论(0)
发评论
下载排行榜
