开关电容变换器在能量收集电路中提供了性能和灵活性
消耗积分:0 | 格式:rar | 大小:0.12 MB | 2017-06-17
分享资料个
  对于能量收集应用,提高电源电压或提供负电源轨的能力在电路设计方面提供了极大的灵活性。开关电容变换器提供了更复杂的电源方案的简单替代,并提供更多的好处,更熟悉的电感为基础的转换器。工程师可以基于开关电容转换器制造商包括模拟设备,Exar,Intersil,线性技术,单片机技术的柔性供应电路建立能量收集设计,德克萨斯文书,其中。
  一般来说,效率大于90%,开关电容电压转换器依赖于一个简单的基本拓扑结构被修改,以反转或加倍的输入电压。在逆变器配置(图1a)中,电容C1在开关周期的前半部分被输入到输入电压。电压倒置,适用于电容C2以及开关周期后半部分的负载。这里,输出电压是输入电压的负值,平均输出电流大约等于输入电流。在倍压器配置(图1b)中,电容C1在其放电周期中与输入电压串联,使输出电压加倍。这里,平均输出电流大约是输入电流的一半。
  Figure 1: Switched-capacitor converters use the same basic topology for inverting input voltage (A) and doubling input voltage (B) on output. Converters typically integrate basic filtering circuitry to reduce output ripple (Courtesy of Analog Devices)。
  Switched-capacitor converters offer distinct advantages over inductor-based switched regulators. Besides eliminating magnetic design issues, switched capacitors typically feature lower noise and EMI performance. A typical application circuit requires only two external capacitors in contrast with inductor-based solutions, which typically require at least two external capacitors as well as the inductor itself. Along with this minimal component count, the elimination of the physically-large inductor results in an end design that is significantly smaller in PCB area and component height.
评论(0)
发评论
下载排行榜
