低成本微加工传感器为Gyroscopes打开了机会
低成本,大规模生产陀螺仪传感器和各种微机械加工技术正在开辟一系列新的应用。从模拟设备,意法半导体器件,与博世传感器表现出不同的技术,在各种应用中使用微机械陀螺的方法。
陀螺仪正在成为电子系统设计中越来越重要的部分。从最初大量应用汽车安全气囊和导航系统开始,这项技术正在进入许多不同的领域。制造工艺的改进和材料和设计的创新正在提供更小、更低功率的设备,从而开辟了使用和保护设备的新途径。
其他应用程序,如图像稳定,远程信息处理,和电子收费是利用低成本的陀螺仪,但技术也在进入如人机界面(MMI)运动控制的主流应用和家电和机器人。支持测量三个维度的额外成本已经低到足以使陀螺仪的应用,以前只使用一或二维加速度计,如开关显示器的配置文件从纵向到横向,游戏控制器甚至菜单滚动。来自陀螺仪的3D数据可以通过软件转换成更复杂的界面控制,以增强用户体验。
该技术甚至扩展到对保证日志记录的冲击检测和跌落保护,提供关于设备发生的更详细的信息。
The integration of more processing around the micro-machined sensor is also allowing more control of the power consumption. Using separate signal chains for the different axes of movement provides finer control of the power consumption and so supports advanced power management for mobile devices. This enhanced power control also opens up applications in pedometers and step counting, which can be combined with other portable devices and Web applications such as mapping in more sophisticated applications.
STMicroelectronics is one of the leading suppliers of micro-machined accelerometers that combine a single mass with highly integrated processing and interface electronics. TheA3G4250D is a low-power 3-axis angular rate sensor that provides high levels of stability at the zero-rate level and sensitivity over temperature and time. It includes a sensing element and an SPI digital interface to deliver the measured angular rate to the external world. An I²C-compatible interface is also available.
