电荷泵切断开关变换器成本
消耗积分:0 | 格式:rar | 大小:0.17 MB | 2017-07-07
分享资料个
  电荷泵切断开关变换器成本
  开关式DC/DC变换器是便携式设计中的一种电压调节器,因为它灵活、高效。然而,也有一些不利的;特别是,设备需要一个比较大的和昂贵的储能电感。
  另一种方案是Low Dropout(LDO)线性DC / DC转换器,它不使用高频开关,因此可以省去电感器。然而,如果输入和输出电压之间的差异很大,并且只能在降压(降压)配置中工作,那么这些设备本质上是低效的。
  另一种开关替代方案提供了基于电感的设计的大部分效率,并使用了电容器作为开关元件,节省了成本和空间。
  本文考虑了开关电容DC/DC转换器(“电荷泵”)的优点,并提出了它们可能是比开关电感芯片更好的选择。综合解决方案(包括机上调节)的格言,Exar,德克萨斯文书被描述为提供给设计工程师最新设备的例子。
  电荷泵切断开关变换器成本
  Trimming the inductor bulk
  Charge pump DC/DC converters have been available for many years, but with all the excitement over the latest high frequency, efficient, and compact inductor-based voltage regulators, these switched capacitor designs are often overlooked. For many applications, charge pumps are a good choice.
  Switching DC/DC converters have become very popular because they are more efficient than linear designs. Linear converters have their place (see TechZone article “High Efficiency, Low Voltage Conversion with Single Supply Operation from an LDO Regulator”), but are inefficient if the voltage difference between input and output is large. The resistor element that drops down the voltage dissipates a lot of power and generates heat.
评论(0)
发评论
下载排行榜
