®iCoupler数字隔离器提供关键的好处在太阳能光伏逆变器光电耦合器
消耗积分:0 | 格式:rar | 大小:0.09 MB | 2017-07-15
分享资料个
  不论在考虑太阳能光伏逆变器系统的类型是否是一个系统的中央逆变器,或是否采用分布式微逆变器,或许这是一个新的直流优化器,借用类型实施隔离是必要的。这是不可避免的,因为系统的各个部分在非常不同的直流和交流电平下工作。也有监管问题,要求最低的电气隔离屏障,以满足安全的原因。
  由于其广泛的可用性和功能性,传统上被用来提供光耦隔离。然而,光电耦合器的使用该应用已经引起了担忧,由于众所周知的不足;最值得注意的是,在电流传输比(CTR)的降解,在设备的使用寿命。为了减轻对CTR退化,光耦电路的设计通常是严重超载,将带来一系列的问题,包括散热和熄灭。即使有一个过度驾驶制度,这是值得怀疑的设备是否将持续标准的20年寿命,许多这样的逆变器提供。
  Analog Devices’ digital isolators with iCoupler® technology enable designers to implement isolation in designs without the cost, size, power, performance, and reliability constraints found with optocouplers. With more than half a billion channels shipped into the field, these magnetically isolated products are a safe, reliable and easy-to-use alternative to optocouplers. Furthermore, the technology allows isolated power to be incorporated in addition to the digital signal isolation functionality. In an inverter, isolated power can be utilized to offer complete isolated gate driver products with low power consumption and tight timing characteristics across all conditions. In contrast, the optocoupler-based gate drivers are very power hungry and also suffer from large variations in the gate driver timing specifications.
评论(0)
发评论
下载排行榜
