mp4030可控硅调光初级侧控制有源PFC的离线led控制器
消耗积分:0 | 格式:rar | 大小:0.78 MB | 2017-09-12
分享资料个
  The MP4030 is a TRIAC-dimmable, primary-sidecontrol, offline LED lighting controller with active PFC. It can output an accurate LED current for an isolated lighting application with a single-stage converter. The proprietary real-current-control method can accurately control the LED current using primary-side information. It can significantly simplify LED lighting system design by eliminating secondary-side feedback components and the optocoupler. The MP4030 implements power-factor correction and works in boundary-conduction mode to reduce MOSFET switching losses. The MP4030 has an integrated charging circuit at the supply pin for fast start-up without a perceptible delay. The proprietary dimming contraol expands the TRIAC-based dimming range. The MP4030 has multiple protections that greatly enhance system reliability and safety, and include over-voltage protection, short-circuit protection, programmable primary-side overcurrent protection, supply-pin under-voltage lockout, and over-temperature protection. All fault protections feature auto-restart. The MP4030 is available in an 8-pin SOIC package.
评论(0)
发评论
下载排行榜
