飞思卡尔半导体文件编号vybridfseriesec数据表:技术数据
消耗积分:0 | 格式:rar | 大小:2.27 MB | 2017-09-19
分享资料个
  1.1 Determining valid orderable parts Valid orderable part numbers are provided on the web. 1. To determine the orderable part numbers for this device, go to www.freescale.com and search the required part number. The part numbering format is described in the section that follows. Part identification 2.1 Description Part numbers for the chip have fields that identify the specific part. You can use the values of these fields to determine the specific part you have received. 2.2 Part Number Format The figure below represents the format of part number of this device.
评论(0)
发评论
下载排行榜
