tsv85x,tsv85xa低功耗高精度通用运算放大器数据表
消耗积分:0 | 格式:rar | 大小:0.78 MB | 2017-09-25
分享资料个
  The TSV85x, TSV85xA series of single, dual, and quad operational amplifiers offer low voltage operation with a rail-to-rail output swing. The TSV85x, TSV85xA series outperforms the industry standard LMV321, proposing lower supply voltage capability, enhanced input offset voltage, and smaller packages. The devices are offered with either industry standard pinouts or with a power-saving shutdown feature that reduces the supply current to a maximum of 50 nA at 25 °C. The wide temperature range, high ESD tolerance, and automotive grade qualification ease the use in harsh automotive applications.
评论(0)
发评论
下载排行榜
