LC2 MOS八进制8位数模转换器ad7228a数据表
消耗积分:0 | 格式:rar | 大小:0.38 MB | 2017-10-14
分享资料个
  The AD7228A contains eight 8-bit voltage-mode digital-toanalog converters, with output buffer amplifiers and interface logic on a single monolithic chip. No external trims are required to achieve full specified performance for the part. Separate on-chip latches are provided for each of the eight D/A converters. Data is transferred into the data latches through a common 8-bit TTL/CMOS (5 V) compatible input port. Address inputs A0, A1 and A2 determine which latch is loaded when WR goes low. The control logic is speed compatible with most 8-bit microprocessors. Specified performance is guaranteed for input reference voltages from +2 to +10 V when using dual supplies. The part is also specified for single supply +15 V operation using a reference of +10 V and single supply +5 V operation using a reference of +1.23 V. Each output buffer amplifier is capable of developing +10 V across a 2 kΩ load. The AD7228A is fabricated on an all ion-implanted, highspeed, Linear Compatible CMOS (LC2 MOS) process which has been specifically developed to integrate high-speed digital logic circuits and precision analog circuits on the same chip
评论(0)
发评论
下载排行榜
