大功率无人机图传控制WiFi模块
消耗积分:0 | 格式:pdf | 大小:1.15 MB | 2017-10-20
天工测控
分享资料个
大功率无人机图传控制WiFi模块。图传控制实时进行,传输距离2000m。模块内部集成了双路PA和LNA,每路发射输出功率可达+28dBm以上。空旷地带有效数据传输距离可达1000米以上,用户利用它可以轻松实现远距离数据传输功能。
  The SKW77 is a highly power wifi module, it compliant to 802.11 b/g/n Wi-Fi Solution for highly performance WLAN requiring up to +27dBm output power. The module requiring a external 3.3V power supply and a external 5.0V power supply 。 The module based on the single chip MT7620A which integrates an 802.11n 2x2 MAC/BB/radio. It supports 802.11n operations up to 144 Mbps for 20 MHz and 300 Mbps for 40 MHz channel respectively, and IEEE 802.11b/g data rates. The module support bridge mode and AP client mode and router mode.
评论(0)
发评论
下载排行榜
