CMOS 1.8V至5.5V,2.5Ω的SPDT开关复用器微型SC70封装ADG779数据表
消耗积分:0 | 格式:rar | 大小:0.22 MB | 2017-10-24
分享资料个
  The ADG779 is a monolithic CMOS SPDT (single-pole, double-throw) switch. This switch is designed on a submicron process that provides low power dissipation yet gives high switching speed, low on resistance, and low leakage currents. The ADG779 operates from a single supply range of 1.8 V to 5.5 V, making it ideal for use in battery-powered instruments and with the new generation of DACs and ADCs from Analog Devices, Inc. Each switch of the ADG779 conducts equally well in both directions when on. The ADG779 exhibits break-before-make switching action. Because of the advanced submicron process, −3 dB bandwidth of greater than 200 MHz can be achieved. The ADG779 is available in a 6-lead SC70 package.
评论(0)
发评论
下载排行榜
