OV7620 is a highly integrated high resolution (640x480) Interlaced / Progressive Scan Cdigital color / black&white video camera chip. The digital video port supports 60Hz YCrCb 16Bit / 8 Bit format, ZV Port output format, RGB raw data 16Bit/8Bit output format and CCICCIR656 format. The built-in SCCB (Serial Camera Control Bus) interface provides an easof controlling the built-in camera functions.1.1 FEATURES• Single chip digital color/black&white video camera chip.• Scanning - Interlaced / Progressive Scan.• Format - 1/3” lens compatible.• Image area -4.86X 3.64mm.• Total active pixel elements - (H)664 x (V)492 square pixel.• Default active pixel element -(H)640 x (V)480.• Pixel size: 7.6 x 7.6um.• 10Bit two channel internal A/D Converter and 8/10 Bit Output.• PCLK and HREF polarity programmable.• Digital Output format -
YCrCb 16bit/8bit selectable60Hz 16 Bit YCrCb 4:2:2 - 640x48060Hz 8 Bit YCrCb 4:2:2 - 640x480RGB Raw Data Digital Output 16Bit/8Bit selectable• Two-line output:
• Y Channel: B G B G B G 。..• UV Channel: G R G R G R 。..Two-line alternate output:Y Channel: G G G G G G 。..UV Channel: B R B R B R 。..One-line output, use Y Channel only, effective only in Progressive Scan Mode1st line: B G B G B G B G.。.2nd line: G R G R G R G R 。..• CCIR601 /CCIR656 standard.• YCrCB or YUV output format to support TV or monitor display• ZV Port YUV 16 Bit format.• QVGA format(320x240)。• Y/UV or RGB output byte MSB and LSB swap.• SCCB interface, support fast mode: 400 kBit/s.• External Field Sync input.• External Horizontal / Vertical Sync input format, OV7620 worked as slave chip.• Support external micro-controller and RAM interface• Progressive Scan mode: support whole-frame exposure.• Programmable frame rate - 0.5 to 30fps.• Electronic shutter setting (use 27Mhz crystal and default clock rate).Interlaced: 1/60 to 1
/15734(
