微处理器监控电路ADM8698/ADM8699数据表
消耗积分:0 | 格式:rar | 大小:0.10 MB | 2017-10-26
分享资料个
  The ADM8698/ADM8699 supervisory circuits provide power supply monitoring and watchdog timing for microprocessor systems. The ADM8698 monitors the 5 V VCC power supply and generates a RESET pulse during power up, power down and during low voltage “Brown Out” conditions. The RESET output is guaranteed to be functional (logic low) with VCC as low as 1 V. The ADM8699 features an identical monitoring circuit as in the ADM8698, plus an additional watchdog timer input to monitor microprocessor activity. The RESET output is forced low if the watchdog input is not toggled within the 1 second watchdog timeout period. Both parts are available in 8-pin plastic DIP/SOIC and 16-lead SOIC packages. The 16-lead SOIC contains additional outputs RESET (without inversion) and Watchdog Output WDO (ADM8699 only).
评论(0)
发评论
下载排行榜
