CS8900A网卡芯片介绍
消耗积分:0 | 格式:rar | 大小:2.31 MB | 2017-10-30
分享资料个
  The CS8900A is a low-cost Ethernet LAN Controller optimized for the Industry Standard Architecture (ISA) bus
  and general purpose microcontroller busses. Its highlyintegrated design eliminates the need for costly external
  components required by other Ethernet controllers. The
  CS8900A includes on-chip RAM, 10BASE-T transmit
  and receive filters, and a direct ISA-Bus interface with
  24 mA Drivers.
  In addition to high integration, the CS8900A offers a
  broad range of performance features and configurationoptions. Its unique PacketPage architecture
  automatically adapts to changing network traffic patterns and available system resources. The result is
  increased system efficiency.
  The CS8900A is available in a 100-pin LQFP package
  ideally suited for small form-factor, cost-sensitive Ethernet applications. With the CS8900A, system engineers
  can design a complete Ethernet circuit that occupies
  less than 1.5 square inches (10 sq. cm) of board space.
CS8900A网卡芯片介绍
评论(0)
发评论
下载排行榜
