MAXQ1050的评估套件和面向MAXQ30入门的CrossStudio编译
消耗积分:0 | 格式:rar | 大小:2.92 MB | 2017-10-31
分享资料个
  The MAXQ1050 is a low-power secure microcontroller, designed for USB secure token and smart card reader
  applications that require certificate-based or other public key cryptographic schemes. The device uses the 32-bit,
  pipelined, MAXQ30 microcontroller CPU. The MAXQ1050 has 128KB flash memory, 12KB of volatile SRAM, 4KB of
  battery-backed NV SRAM, and 256B of battery-backed secure zeroization NV SRAM.
  The microcontroller is powered either from the USB bus or by a separate 3.3V supply. A battery connection is provided
  for applications that need to maintain data in the NV SRAMs. In battery-backed mode, the NV SRAM and security
  sensors consume less than 240nA (typ)。
  The MAXQ1050 has a number of important features, including:
评论(0)
发评论
下载排行榜
