2.General Description MT7668SN is highly integrated single chip which features a low power 2x2 11a/b/g/n/ac dual-band Wi-Fi subsystem and a Bluetooth subsystem. The Wi-Fi subsystem contains the 802.11a/b/g/n/acradio, baseband, and MAC that are designed to meet both the low power and high throughput application. MT7668S N has a 32-bit RISC MCU that handles Wi-Fi and Bluetooth tasks, and an ARM Cortex-R4 MCU that could offload data frame processing in Wi-Fi host driver. The Bluetooth subsystem contains the Bluetooth radio, baseband, link controller. It also uses the 32-bit RISC MCU for the Bluetooth protocols. 3. Features n Highly integrated 28nm RFCMOS technology n 9x9 QFN76 pins package n Integrate high efficiency power management unit with single 3.3V power supply input n 26, 40, 52MHz crystal clock support with low power operation in idle mode n Buffered clock output for co-clock with other SOC chipset n 32-bit RISC MCU for Wi-Fi/Bluetooth protocols n ARM Cortex-R4 MCU for Wi-Fi offload n Embedded SRAM/ROM n SDIO device fully complianttoSDIO3.0 specification n UART interface with hardware flow control n Programmable and multiplexed GPIO pins n IEEE 802.11 a/b/g/n/ac compliant n Support 20MHz, 40MHz, 80Mhz bandwidth in 2.4GHz band 5GHz band n Dual-band 2T2R mode, data rate up to 450Mbpswith SDIO3.0. n Support MU-MIMO RX and DBDC (dual band dual concurrent) n Support STBC, LDPC, TX Beamformer and RX Beamformee n Greenfield, mixed mode, legacy modes support n IEEE 802.11 d/e/h/i/j/k/mc/r/v/w support n Security support for WFA WPA/WPA2 personal, WPS2.0, WAPI n QoS support of WFA WMM, WMM PS n Integrated LNA, PA, and T/R switch n Bluetooth specification 2.1+EDR n Bluetooth 4.2Low Energy (LE)
全部2条评论
