开源硬件-PMP20339.1-85VAC 至 264VAC 输入、12V/450mA 和 5V/50mA 双路输出偏置电源 PCB layout 设计
消耗积分:0 | 格式:pdf | 大小:453.92KB | 2023-08-16
分享资料个
The PMP20339 is a low cost bias supply reference design with 12V/450mA and 5V/50mA outputs from 120VAC input. A dual-output flyback converter with UCC28700 primary-side regulation controller is used to generate 12V and 5V outputs. Single layer PCB is applied to reduce the overall BOM cost.
评论(0)
发评论
下载排行榜
