HP VEE 5.0下载
消耗积分:0 | 格式:rar | 大小:未知 | 2010-01-26
杨海清
分享资料个
HP VEE 5.0下载:HpVee for Windows is a data acquisition program that can control and communicate with a piece of test equipment over a General Purpose Interface Bus (GPIB, also known as HPIB or IEEE 488) cable. The software at present is only available in the electrical engineering department on stand-alone PC's. So far only two computers are running the current software the Windows 95 PC in the Microwave lab and the Sony laptop. (Use the start menu in Windows 95 to select and run the HpVee environment.) There are two types of HpVee programs discussed in this document - runtime programs (extension .vxe) and program environment software (extension .vee). Runtime software cannot be modified and can be run from a Dos window (It can also be run inside the HpVee environment) with the runtime compiler. The following is an example of the usage of the runtime compiler on the Windows 95 PC in the Microwave Lab:
评论(0)
发评论
下载排行榜
