浅析STM32F105xx和STM32F107xx的异同
消耗积分:0 | 格式:pdf | 大小:1.84 MB | 2018-07-17
一袭青衫
分享资料个
  Features
  ■ Core: ARM 32-bit Cortex™-M3 CPU
  – 72 MHz maximum frequency,
  1.25 DMIPS/MHz (Dhrystone 2.1)
  performance at 0 wait state memory
  access
  – Single-cycle multiplication and hardware
  division
  ■ Memories
  – 64 to 256 Kbytes of Flash memory
  – 64 Kbytes of general-purpose SRAM
  ■ Clock, reset and supply management
  – 2.0 to 3.6 V application supply and I/Os
  – POR, PDR, and programmable voltage
  detector (PVD)
  – 3-to-25 MHz crystal oscillator
  – Internal 8 MHz factory-trimmed RC
  – Internal 40 kHz RC with calibration
  – 32 kHz oscillator for RTC with calibration
  ■ Low power
  – Sleep, Stop and Standby modes
  – VBAT supply for RTC and backup registers
  ■ 2 × 12-bit, 1 µs A/D converters (16 channels)
  – Conversion range: 0 to 3.6 V
  – Sample and hold capability
  – Temperature sensor
  – up to 2 MSPS in interleaved mode
  ■ 2 × 12-bit D/A converters
  ■ DMA: 12-channel DMA controller
  – Supported peripherals: timers, ADCs, DAC,
  I
  2Ss, SPIs, I2Cs and USARTs
  ■ Debug mode
  – Serial wire debug (SWD) & JTAG interfaces
  – Cortex-M3 Embedded Trace Macrocell™
  ■ Up to 80 fast I/O ports
  – 51/80 I/Os, all mappable on 16 external
  interrupt vectors and almost all 5 V-tolerant
  ■ CRC calculation unit, 96-bit unique ID
  ■ Up to 10 timers with pinout remap capability
  – Up to four 16-bit timers, each with up to 4
  IC/OC/PWM or pulse counter and
  quadrature (incremental) encoder input
  – 1 × 16-bit motor control PWM timer with
  dead-time generation and emergency stop
  – 2 × watchdog timers (Independent and
  Window)
  – SysTick timer: a 24-bit downcounter
  – 2 × 16-bit basic timers to drive the DAC
  ■ Up to 14 communication interfaces with pinout
  remap capability
  – Up to 2 × I2C interfaces (SMBus/PMBus)
  – Up to 5 USARTs (ISO 7816 interface, LIN,
  IrDA capability, modem control)
  – Up to 3 SPIs (18 Mbit/s), 2 with a
  multiplexed I2S interface that offers audio
  class accuracy via advanced PLL schemes
  – 2 × CAN interfaces (2.0B Active) with
  512 bytes of dedicated SRAM
  – USB 2.0 full-speed device/host/OTG
  controller with on-chip PHY that supports
  HNP/SRP/ID with 1.25 Kbytes of dedicated
  SRAM
  – 10/100 Ethernet MAC with dedicated DMA
  and SRAM (4 Kbytes): IEEE1588 hardware
  support, MII/RMII available on all packages
评论(0)
发评论
下载排行榜
