基于HN-85 1200XH下的规格书
消耗积分:1 | 格式:pdf | 大小:1.46 MB | 2018-08-03
efans_c11
分享资料个
  适用范围 Scope
  1-1. 本规格书适用于 HN-85 型车用 DVD 播放机机芯(简称 DVD 机芯); This specification is only suitable for HN-85 mechanism of DVD player for car (thereafter called DVD mechanism)。
  1-2.对本规格书有疑义时,由深圳市海纳精密五金塑胶有限公司工程部负责解释。 Any query over the specification shall be expressed by development department of Shenzhen Haina Precision metal&Plastic Co.,Ltd.
  2.外观尺寸及安装方式 Dimension of shell and mode of installation
  2-1. 外形尺寸及安装方式参照附件。 See attachment for drawing of dimension of shell
  3.一般规格 General specification
  3-1 结构系统 Mechanism system
  3-1-1.进碟:马达驱动载入方式(皮带传动) Disc loading:Motorized loading(Belt drive)
  3-1-2.出碟:马达驱动出碟方式(皮带传动) Disc ejecting:Motorized ejection(Belt drive)
  3-1-3.播放:进碟→播放方式 Play:Loading→play method
  3-1-4.光头调整方式:四点支撑,三点调整。 Adjusting mode of pick up:four points support, three points adjust.
  3-1-5.光头驱动方式:进给马达一级减速带动齿条驱动方式 Pick-up drive mode:feeding motor 1 steps deceleration drive rack plate.
  3-1-6. 光头移动范围:由主轴马达中心开始 22.5~59.5mm Range of Pick-up movement:22.5~59.5mm from the center of spindle motor.
  3-1-7.抗振:三个含油硅胶弹性体(组装油球 A、B)和弹簧组合抗振方式 Anti vibration:3 silicon elasticity dampers(ball Assemble the oil ball A、B) and springs method.
  3-2 电源电压(使用敝司标准回路或同等品) Voltage of power supply (use HAINA′s standard circuit,or the equivalent): +5V DC with ±5% tolerance, less than 50m Vp-p Ripple Voltage(1.0A/1.5A Max) +12V DC with ±5% tolerance, less than 50m Vp-p Ripple Voltage(100mA/200mA Max)
  3-3 光头 Pick-up 3-3-1.光头:HOP-1200XH 单激光发射管单物镜光头 pick up :HOP-1200XH one laser diode and single object lens pick up.
  3-3-2. 出射光波长:CD:785nm±22nm ;DVD:658nm±15nm 。 Wave length of laser:CD: CD:785nm±22nm ;DVD:658nm±15nm 。
基于HN-85 1200XH下的规格书
评论(0)
发评论
下载排行榜
