INA212/INA214 pdf datasheet (V
消耗积分:0 | 格式:rar | 大小:666 | 2008-08-19
479461
分享资料个
The INA210, INA211, INA212, INA213, and INA214 are voltage output current shunt monitors that can sense drops across shunts at common-mode voltages from -0.3V to 26V, independent of the supply voltage. Five fixed gains are available: 50V/V, 100V/V, 200V/V, 500V/V, or 1000V/V. The low offset of the Zerø-Drift architecture enables current sensing with maximum drops across the shunt as low as 10mV full-scale.
These devices operate from a single +2.7V to +26V power supply, drawing a maximum of 100µA of supply current. All versions are specified over the extended operating temperature range (-40°C to +125°C), and offered in an SC70 package.
评论(0)
发评论
下载排行榜
