ADS8556,pdf (Simultaneous Samp
消耗积分:0 | 格式:rar | 大小:876 | 2010-06-03
李军
分享资料个
The ADS8556/7/8 contain six low-power, 16-, 14-, or 12-bit, successive approximation register (SAR) based analog-to-digital converters (ADCs) with true bipolar inputs. Each channel contains a sample-and-hold circuit that allows simultaneous high-speed multi-channel signal acquisition.
The ADS8556/7/8 support data rates of up to 730kSPS in parallel interface mode or up to 500kSPS if the serial interface is used. The bus width of the parallel interface can be set to eight or 16 bits. In serial mode, up to three output channels can be activated.
The ADS8556/7/8 is specified over the full industrial temperature range of -40°C to +125°C and is available in an LQFP-64 package.
评论(0)
发评论
下载排行榜
