MAX11040pdf (Cascadable Sigm
消耗积分:0 | 格式:rar | 大小:123 | 2010-06-14
张伟
分享资料个
The MAX11040 is a 24-bit, 4-channel, simultaneoussampling,sigma-delta analog-to-digital converter (ADC). The device allows simultaneous sampling of as many as 32 channels using a built-in cascade feature to synchronize as many as eight devices. The serial interface of the MAX11040 allows reading data from all the cascaded devices using a single command. Four
modulators simultaneously convert each fully differential
analog input with a programmable data output rate
ranging from 0.25ksps to 64ksps. The device achieves
106dB SNR at 16ksps and 117dB SNR at 1ksps. The
MAX11040 operates from a single +3V supply. The differential
analog input range is ±2.2V when using the internal reference, an external reference is optional.Each input is overvoltage protected up to ±6V without damage. The device uses an internal crystal oscillator  or an external source for clock.
评论(0)
发评论
下载排行榜
