TMS3705,pdf(TRANSPONDER BASE S
消耗积分:0 | 格式:rar | 大小:381 | 2010-06-29
张丽
分享资料个
The transponder base station IC is used to drive the antenna of a TI-RFid transponder system, to send data modulated on the antenna signal, and to detect and demodulate the response of the transponder. The response of the transponder is a FSK signal (frequency shift keyed). The high or low bits are coded in two different high-frequency signals (134.2 kHz for low bits and 123 kHz for high bits, nominal). The transponder induces these signals in the antenna coil according an internally stored code. The energy the transponder needs to send out the data is stored in a charge capacitor in the transponder. The antenna field charges this capacitor in a preceding charge phase. The IC has an interface to an external microcontroller.
评论(0)
发评论
下载排行榜
