The Evaluation Board for the Q5) Single Chip 430MHz-950MHz RF Transceiver has been developed to enable customers to test the functionality and to verify the performance parameters of the device. The Q5) Evaluation Board has been made for 868MHz operation. This document specifies the usage of the Evaluation Board and suggests some evaluation testbenches. The Evaluation Board is intended for evaluation purposes only. It is not intended for incorporation into an end product. *HWWLQJVWDUWHG To test the Q5) device to its full extent, the following instrumentation should be at your disposal: · A +2.7V to +3.3V variable DC voltage supply, and/or a +4.5V to +16V variable DC voltage supply. · Dual channel oscilloscope · Low frequency generator / digital pattern generator · RF signal generator with FSK modulation capability · RF Spectrum analyser · Bit-error-rate meter (optional)
