高速缓冲存储器Cache在微处理器中已经成为至关重要的一部分,它的使用能有效地缓和CPU和主存之间速度匹配的问题。本文以32位S698M微处理器的高速缓冲存储器Cache为例,分析了Cache的体系结构和关键技术,阐述了$698M中Cache的基本访存过程。该芯片已采用新加坡特许半导体0.18微米CMOS工艺流片成功。
关键词:哈佛体系结构;直接映像;写直达;Cache一致性;指令Cache;数据Cache
Abstract: Cache is a significant part in modern microprocessor。It solves efectively the matching of speed between CPU and main memo~.This paper analysis the architecture and key technology of Cache memo~, describes basic access memo~ processing of Cache memo~ based on a 32-bit RISC microprocessor chip named “$698M”。Th is
SoC processor has been manufactured successfully using Chartered 0.1 87mCMOS technology 。
Keywords:Harvard architecture;Direct-Mapped;Write Through;Cache coherent;I——cache;D——cache
