BQ2004,pdf(Fast-Charge IC)
消耗积分:0 | 格式:rar | 大小:379 | 2010-11-10
131594
分享资料个
The bq2004 Fast Charge IC provides comprehensive fast charge control functions together with high-speed switching power control circuitry on a monolithic CMOS device.
Integration of closed-loop current control circuitry allows the bq2004 to be the basis of a cost-effective solution for stand-alone and system integrated chargers for batteries of one or more cells.
Switch-activated discharge-before charge allows bq2004-based chargers to support battery conditioning and capacity determination.
High-efficiency power conversion is accomplished using the bq2004 as a hysteretic PWM controller for switch-mode regulation of the charging current. The bq2004 may alternatively be used to gate an externally regulated charging current.
评论(0)
发评论
下载排行榜
