OV511 pdf datasheet (low cost
消耗积分:5 | 格式:rar | 大小:555 | 2008-10-17
世态薄凉
分享资料个
OV511+ based on OV511, is a low cost and highly integrated solution for USB PC camera
applications. It remains OV511’s performance unchanged or is improved, while some new
features were implemented. New features include built-in USB transceiver with selectable
external USB transceiver interface, more effective packet size of the isochronous pipe,
programmable LED control, programmable switching power clock with frequencies of
24K/48K/96K/192KHz, etc.
OV511+ is a USB PC camera controller that includes a proprietary compression engine
supporting real time image transfer through USB bus. A complete USB camera system consists
of OV511+, a 256Kx16 EDO DRAM, and a digital camera such as OV7620 for VGA resolution or
OV6620 for CIF resolution.
Camera Interface generates different image formats by taking either 16-bit YUV 4:2:2/RGB raw
data or 8-bit Y 4:0:0/RGB raw data inputs. OmniCE is the proprietary compression engine. It not
only performs 10~15fps for VGA and 30fps for CIF, but also allows very fast decompression with
low CPU utilization. Depending on the camera device that is built with the system, either SCCB
or Parallel IO bus can be chosen. The SCCB bus master uses two dedicated pins “SIO-0” &
“SIO-1”, while the PIO shares with Y & UV buses. Snapshot button allows users to take a high
quality, VGA resolution uncompressed still image
The functional blocks of OV511+, as shown in the following figure, consist of Camera Interface,
DRAM Interface, OmniCE, UDC interface, ISO FIFO, System Control, SCCB and PIO.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
