in4148参数资料,IN4148封装尺寸,IN4148贴片
接口定义
119人已加入
FEATURES
• Small glass structure ensures high reliability
• Fast switching
• Low leakage
• High temperature soldering guaranteed:
250oC/10S/9.5mm lead length
at 5 lbs tension
MECHANICAL DATA
• Terminal: Plated axial leads solderable per
MIL-STD 202E, method 208C
• Case: Glass,hermetically sealed
• Polarity: Color band denotes cathode
• Mounting position: Any
IN4148封装尺寸
封装
in4148参数资料
·反向漏电流小。Low reverse leakage
·开关速度快。Fast switching speed
·最大功率耗散500mW。Maximum power dissipation 500mW
·高稳定性和可靠性。High stability and high reliability
机械数据 Mechanical Data
封装: DO-35 玻璃封装 Case: DO-35 Glass Case
极性: 色环端为负极 Polarity: Color band denotes cathode end
安装位置: 任意 Mounting Position: Any
极限值和温度特性 TA = 25℃ 除非另有规定。
Maximum Ratings & Thermal Characteristics Ratings at 25℃ ambient temperature unless otherwise specified.
in4148参数
封装
in4148特性曲线 Characteristic Curves
封装
