AME1300 pdf datasheet (LDO Reg
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-01
张磊
分享资料个
The AME1300 combines a Low Dropout Regulator and
a Microprocessor Reset Monitor in a space-saving MSOP-
8 package. Total supply current is 50mA (typical), 20 to
60 times lower than in bipolar regulators .
The AME1300 has an extremely precise output with a
typical accuracy of ±1.5%. Other key features include
ultra low noise operation, very low dropout voltage and
internal feed-forward compensation for fast response to
step changes in load. The AME1300 incorporates both
over-temperature and over-current protection. When the
shutdown control EN is low, the regulator output voltage
falls to zero, RESETB output remains valid and supply
current is reduced to 10mA(typical). The AME1300 is
stable with an output capacitor of only 2.2mF and has a
minimum output current of 300 mA.
An active low RESET is asserted when the detected
voltage (VDET) falls below the reset voltage threshold. The
reset output remains low for 300msec(typical) after VDET
rises above reset threshold. The AME1300 also has a
fast wake up response time (10msec typically) when released
from shutdown.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
