The AME5130 is a fixed off-time step-up DC/DC converter in a small 5-lead SOT-25 package.The AME5130 is ideal for LCD panels requiring low current and high efficiency as well as LED applications for cellular phone backlighting, PDAS,and other hand-held devices. The low 400ns off-time allows the use of tiny external components. AME5130 can drive up 8 white LEDs from a single Li- Ion battery DC 2V to 5.5V; can be turned on by putting more than 1V at pin 4(EN). To control LED brightness, the LED current can be pulsed by applying a PWM (pulse width modulated) signal with a frequency range of 100Hz to 50KHz to the EN pin.
