Samsung’s S3C2510A 16/32-bit RISC micro-controller is a cost-effective, high-performance micro-controller solution for Ethernet-based systems, for example, SOHO router, internet gateway, WLAN AP, etc. To efficiently support those network applications, S3C2510A provides the followings: 16/32-bit ARM940T RISC embedded with 4K-byte I-cache and 4K-byte D-cache, memory controller with 24-bit external address pins, one external bus master with bus request/acknowledge pins, two 10/100 Mbps Ethernet controllers, PCI & PC Card host/agent controller, AAL5 SAR and UTOPIA L1/L2, two port full/low speed USB host with root hub, one port USB function device with transceiver, six general-purpose DMAs, two high-speed UARTs, one console UART, DES and 3DES for IP security, IIC serial interface, interrupt controller, six 32-bit programmable timers, 30-bit watchdog timer, 64 programmable I/O ports, and four PLLs for clock generation. The S3C2510A is developed using an ARM940T core, 0.18um CMOS standard cells and a memory compiler. Its powerful, elegant and fully static design is suitable for various network applications. Also S3C2510A adopts a new bus architecture, AMBA (Advanced Microcontroller Bus Architecture).
