Superpro windows XP编程器软件: 1. Install Superpro/580 software on your hard drive:
A) Place the installation disk into disk drive A: or B:. The installation
disk contains five files: INSTALL.EXE, SP6BIN.EXE, SP6LIB.EXE and
SP6ALGO.EXE.
B) Start the installation program, INSTALL.EXE, by typing "A:SETUP
C) Once the installation program starts, it will display a default
drive and path, "C:\WINSP6". You can change this if you would like.
D) Press "
E) The installation program will decompress the software files into
the directory that you specified.
F) At the end of installation you will be asked if you would like the
software to add a pathname to AUTOEXEC.BAT. If AUTOEXEC.BAT
does not exist, it will be created.
