HCS166/HCS166MS pdf datasheet(
消耗积分:2 | 格式:rar | 大小:228 | 2008-12-28
刘芳
分享资料个
The Intersil HCS166MS is an 8-bit shift register that has fully
synchronous serial or parallel data entry selected by an
active LOW Parallel Enable (PE) input. When the PE is LOW
one setup time before the LOW-to-HIGH clock transition,
parallel data is entered into the register. When PE is HIGH,
data is entered into internal bit position Q0 from Serial Data
Input (DS), and the remaining bits are shifted one place to
the right (Q0 → Q1 → Q2m etc.) with each positive-going
clock transition. For expansion of the register in parallel to
serial converters, the Q7 output is connected to the DS input
of the succeeding stage.
评论(0)
发评论
下载排行榜
