IPTV信号发生器-IPG500 (IPTV Stream
消耗积分:5 | 格式:rar | 大小:333 | 2009-01-15
分享资料个
IPTV Stream Generator is a professional and powerful solution adapting MPEG DTV signals for streaming across IP networks. IPTV Stream Generator supports various Ethernet interfaces-10/100/Gigabit output interfaces (Copper & Fiber). Extensive set of optional interface cards are available for your test and development.
IPTV Stream Generator has some special features for IPTV set-top box manufacturing and developing  as below.
Automatic TS verification : Before transmitting, broken TS will be verified and removed automatically.
In a Lab environment, MPEG over IP Stream Generator is the most flexible solution for setting-up MPEG over IP signal environment your engineers need.  With various Ethernet output interfaces, manufacturers can easily set up  manufacturing lines for IPTV and IP set-top box. With User-friendly configuration and GUI, user can control and test MPEG Over IP streaming with support for UDP.
评论(0)
发评论
下载排行榜
