ISL54209 pdf datasheet (MP3/US
消耗积分:2 | 格式:rar | 大小:333 | 2009-01-19
张艳
分享资料个
MP3/USB 2.0 High Speed Switch with Negative Signal Handling and Low Power Shutdown
The Intersil ISL54209 dual SPDT (Single Pole/Double Throw)
switch combines low distortion audio and accurate USB 2.0
high speed data (480Mbps) signal switching in the same low
voltage device. When operated with a 2.5V to 5.0V single
supply, this analog switch allows audio signal swings below
ground, allowing for the use of a common USB and audio
headphone connector in Personal Media Players and other
portable battery powered devices.
The ISL54209 logic control pins are 1.8V compatible, which
allows for control via a standard μcontroller.
The ISL54209 has an audio enable control pin to open all
switches and put the part in a low power state. In this state,
the device draws typically 1nA of current.
The ISL54209 is available in a small 10 Ld 2.1mmx1.6mm
ultra-thin μTQFN package and a 10 Ld 3mmx3mm TDFN
package. It operates over a temperature range of -40°C to
+85°C.
Related Literature
• Technical Brief TB363 “Guidelines for Handling and
Processing Moisture Sensitive Surface Mount Devices
(SMDs)”
• Application Note AN1406 “ISL54209EVAL1Z Evaluation
Board User’s Manual”
评论(0)
发评论
下载排行榜
