ISL8540 pdf datasheet (DC/DC P
消耗积分:5 | 格式:rar | 大小:333 | 2009-02-10
张虎豹
分享资料个
The ISL8540 is a step down DC/DC power switching
regulator which accepts 9.0V to 40V input and provides a 2A
output current. The output voltage can be set in the range
between 1.21V and 35V by means of an external divider.
The device uses an internal power DMOS transistor with a
typical rDS(ON) of 0.19Ω to obtain very high efficiency and
high switching speed. A switching frequency in the range of
100kHz to 600kHz can be realized (the maximum power
dissipation of the various packages must be observed).
Notable features of this next generation of DC/DC converter
include pulse-by-pulse current limit for FET protection,
hiccup mode for short circuit protection, voltage feedforward
regulation, Frequency SYNC, soft-start, low standby current
of 60μA typical in the disabled state, and thermal shut-down.
The device is available in a 20 Ld HTSSOP package.
评论(0)
发评论
下载排行榜
